Today I was the happy witness of the birth of some new watherfleas.
The difference in background colours is the result of experimenting with colour temperature.
Wow that looks amazing. Tell me what experiments you did with regard to the colour temperature. I'm really interested in that because I have a lamp for a Zeiss KF stand but the colour temperature is horrid
Thanks, I use a Canon EOS 50D camera with Canon software at the PC.
The microscope has a halogen lamp.
In the software (or at the camera) I can change the white balance and that gives different background colours. I can also change the colour temperature with the same result. 2400 Kelvin gives a deep blue colour,
3600 Kelvin gives red/brown and other colours I get between that.
Your images are slowly getting better and better. The first image has a nice neutral grey background.
And about the birth. I hope I don't spoil the party by pointing out that the pressure of the coverslip made it a bit of a premature birth. I doubt that they lived happily ever after.
Jan, of course I was teasing a bit. Your images are very nice. There is a good method to ensure the safety of the organisms. When you use dots vaseline under the corners of the cover slip. (you can add the vaseline in a plastic syringe without the needle) you can make a deep slide.
By removing the water with a piece of bloting paper you can make the slide flatter until the waterflea is slightly pressed. I always use this method and after I have photographed the organisms I can add some water with a pipette, remove the coverslip and this way I can actually put the organisms back in the petri dish.
I use Wax Base Plates. Every dentist has those and they are cheaply available at Ebay, too. I scratch the wax plate with each corner of the coverslip and voila, I have 4 little feet!
