Female human flea
gpmatthews
Female human flea
Post by gpmatthews »
Microscope: Zeiss Standard
Objective: Leitz 16/0.45 ICT NPL Fluotar
Substage: Leitz ICT 0.9NA
77 tile mosaic stitched from stacked images
This is a low resolution image, for an idea of the full size image, see this tour:
http://youtu.be/QsHbS8LLIYs
Graham
Very impressive image. I know how tricky it is to do these high shutter count stack and stitches, particularly using higher magnification objectives above X10. The video gives a much better idea of how much detail is 'hidden' in these images and is an interesting alternative way to present them I hadn't considered. How deep were the individual stacks? There must be a very large number of actual individual images in this composite.
Post by Planapo »
Wow, excellent, Graham!
Parts do remind me of photos of the moon's surface.
Was that done with oblique illumination?
--Betty
gpmatthews
Betty - the image was taken using DIC (ICT in "Leitz-speak"), hence the pseudo-3D effects
Graham
Post by Mitch640 »
Excellent work on the image and the video. It looks like the steamroller got him first though. :)
NikonUser
Post by NikonUser »
Mitch640 wrote:It looks like the steamroller got him first though. :)
Always the case, that's why they make excellent photos, in the right hands of course.
NU.
student of entomology
Oliver Wendell Holmes, Sr
Tom Jones
Post by Tom Jones »
Graham,
Very nice work! A question on the video though. What software did you use for displaying/zooming and recording the image as a movie? I've used Zoomify in the past but this is much smoother and faster, and as I recall, Zoomify can't record anything.
Tom
gpmatthews
The video capture was done using Total Recorder VideoPro (see http://www.totalrecorder.com ). This enables onscreen capture from a defined window. Under Windows 7 one can save in MPEG4 format. I also used Total Recorder for capturing audio when I digitised my LP collection. Display and zooming/panning of the image used the Picasa viewer.
CactusDave asked how many images per stack - variable, but mostly around 9. The original images were shot at 4752x3168 pixels, but resized for the stack and stitch to 2500x1667 and dustmap filtered using Helicon Filter (this is why I keep hassling Rik about adding a dustmap facility in Zerene). This was my first serious attempt at a large stack & stitch image and the overlaps for the "tiles" were not quite enough to use MS ICE comfortably, so although MS ICE did quite a bit of the work, I had to complete the job manually using cloning.
Graham
gpmatthews wrote:(this is why I keep hassling Rik about adding a dustmap facility in Zerene)
It's not hassling; you're just gently reminding me of the importance and value of this highly desired new feature. :roll: Noted and appreciated! :D
Perl
DIC
Post by Perl »
Graham !
Picuture is very nice - But DIC effect not so strong :lol:
Best Regards
Pär
****** Seeing is Believing ******
gpmatthews
Pär - DIC effect is OK at x16, but as you say not so strong - uniform illumination is a problem with the 16ICT objective - I think this is the extreme lower end of the condenser's abilities.
Graham
Perl
Post by Perl »
Yes Graham !
Agree to that - Have A setup
where i chance the ICT Objectices
agains POL Objectives with DIC Sliders
Much better ( More adjustable )
But this is not Leitz Standard DIC Setup
more like the one on Reichert Zetopan
And it give more option of mag / Objectives
and are more easy to work with
Regards
Pär
