The fruiting body plucked from behind the head of one of the ants I have been studying, was placed in a petri dish with an alcohol and mild detergent solution (Palmolive) for softening and allowed to sit over 24hrs. A squash prep was attempted but with very minimal results, this thing is tuff. For those of you who are familar with the old Palmolive adds on american TV, sorry "Madge" you have met your match. The ad promised that it would soften hands while doing dishes, not fruiting bodies from pathogenic fungal parasites.
The fruiting body did soften but only to a very small degree, enough to allow me to get two shots at the base of the specimen. Both images were photographed through a 40X/0.65 Zeiss CP Achromat, due to the base being thicker than the rest of the specimen, the cover slip sat at an angle, not allowing oil immersion to be used, however I did try it but was unsuccessful due to the fact the objective came into contact with the cover slip, so instead of going on I aborted the attempt.
Ascomycetes reproduce by means of a bag like structure, an ascus. It may contain 8 or more spores, in the image to the right (center) the seemingly bag like structure rising up may be and ascus but I am not sure. However to the left, I did manage to capture some hyphal filaments at the base, note that there are some, what appears to be "spherical bodies," these may or may not be spores.
