Super colorful fluorescent plant seed [+ Picture added]
Playing around with fluorescent dyes I found an interesting combination:
Notice the nuclei in the seedling. Also sorry I was unable to upload bigger size of the pic on which it looks much better with lots of details, forum limits.
Actually in my previous post I showed a collection of best pictures that I've got, now I'll be posting mostly from the trash folder with less successful work.
stack of 90 pictures,
10x lens
Zeiss Axiostar
Mercury UV lamp
Canon Powershot G10
10x lens
Zeiss Axiostar
Mercury UV lamp
Canon Powershot G10
Thanks for pointing that out, in this case I used photoshop to stack it automatically (2 stacks combined into a single image) with some manual retouching and editing background after stitching. In this case it was easy as the object was not a moving one, I had time for longer exposures resulting in getting better quality pictures which PS was able to understand. It seldom happens though=(
I am not that insane to do 90 pics totally manually, besides 40-50 would be more than enough in this case
Psst! If you split a "tall" image like this into two each 1024 square, you can post one straight above the other.forum limits.
I think we are all used to scrolling the screen
You can of course post elsewhere, eg flickr, Imageshack etc and give the link, as an addition to hosting the smaller image here.
- arturoag75
Thank you for the additional information.Starshade wrote:Thanks for pointing that out, in this case I used photoshop to stack it automatically (2 stacks combined into a single image) with some manual retouching and editing background after stitching. In this case it was easy as the object was not a moving one, I had time for longer exposures resulting in getting better quality pictures which PS was able to understand. It seldom happens though=(
Another example of how stacking software is missing narrow parts when dealing with fluorescent images.
Be aware that Photoshop's stacking methods are the weakest of any commonly used tool. It's very prone to leaving fuzzy regions even in stacks that other software handles perfectly.
You would have better odds using one of the dedicated stacking programs such as Zerene Stacker, CombineZP, or Helicon Focus. The image shown here has quite a bit of fine detail that should make it pretty well behaved. The images shown in your other thread have less fine detail, which makes life tougher for any stacking software.
Overall I think your best bet would be Zerene Stacker's PMax method. It is very tolerant of subjects that have no fine detail and/or have details overlapping at different depths. ZS also provides a synthetic stereo function that lets you generate stereo pairs from a single stack. See http://zerenesystems.com/cms/stacker/do ... eticstereo for some more information about that, and http://www.photomacrography.net/forum/v ... hp?t=13982 for some recent examples in the forum here.
Motion of the subject will be a problem with any software. None of the packages understand how to warp an image so as to keep moving parts lined up from frame to frame.
Thank you for comments,
Rik, on this particular picture indeed I did not try zerene and I know it has better and sharper details.
However at the beginning I had 2 desktops and a laptop with 5 screens in total and I decided to try all possible options with Zerene, Helicon and Photoshop running between computers to save time and came to the conclusion that in an average fluorescent image project it's easier to use PS manually as I have the best control over what I am doing and to my surprise it was taking less time than correcting and retouching loads of images produced with different algorithms of stacking software... mainly because it's hard to get good details in fluorescent pics.
Why I didn't like Zerene in fluorescent stacking is that I either get noisy piece of... image or it gets too soft and losing details so I decided to make the first attempt with this seed with PS.
But now I do want to try using Zerene to make stereo images and getting possibly a better final stack
In any case the reason why I got suitable final pictures was because I had only few (5-30) images to stack
That sounds pretty comprehensive to me -- experiment beats conjecture any day!Starshade wrote:However at the beginning I had 2 desktops and a laptop with 5 screens in total and I decided to try all possible options with Zerene, Helicon and Photoshop running between computers to save time and came to the conclusion that in an average fluorescent image project it's easier to use PS manually as I have the best control over what I am doing and to my surprise it was taking less time than correcting and retouching loads of images produced with different algorithms of stacking software... mainly because it's hard to get good details in fluorescent pics.
Yes, one of the drawbacks to PMax is that it increases noise a lot. If you're having to work at high ISO due to low light levels, then you'll get better results from a method that strongly prefers to select neighboring pixels from the same image. Photoshop is a good choice in that case.Why I didn't like Zerene in fluorescent stacking is that I either get noisy piece of... image or it gets too soft and losing details so I decided to make the first attempt with this seed with PS.
Well, I am still not satisfied with the quality results so to speak.
And no wonder no one does fluorescent photography, it takes insane amount of time and patience, basically in average I have 2-3 usable shots out of 500 (this object being an exception), moving objects and long exposures don't do well together. Immobilizing critters does not give good coloration options. And I'm not even mentioning photo editing which is a total frustration in the majority of cases.
