NikonUser wrote:Spiracles need to be open spaces for the passage of air in and CO2-laden air out. The spiracle in Rik's image appears not to allow any gas movement.
Well, they certainly need to be open for respiration. However, as noted in "The Insects / Structure and Function", pages 449-450,
The spiracles of most terrestrial insects have a closing mechanism which is important in the control of water loss.
The spiracles are normally open for the shortest time necessary for efficient respiration presumably to keep water loss from the tracheal system to a minimum
I discount the possibility of fungus since the caterpillar I photographed appeared perfectly healthy from the time I noticed its appearance until several weeks later when I inadvertently froze it while trying to chill it into complete quiescence. Also there was nothing special about that one particular spiracle -- all spiracles on the caterpillar looked the same.
My own guess is that the spiracle I photographed just happened to be closed at the time I photographed it, and we're looking at exterior texture of the closing flaps. Alternatively, the spiracle may be open, but filled with a dense mat of filter hairs such as illustrated in the SEM image
HERE. Google image search on
spiracle shows many cases that look similar to mine, though not at such high magnification.
It would be nice to have pictures of the same individual with spiracles open versus closed, but I couldn't find any of those. The idea of open versus closed is well illustrated
HERE, last image, but that's with two very different critters.
I do agree that NikonUser's image is an excellent illustration of an open spiracle. The filtering hairs are very well captured. I haven't seen those clearly rendered in optical before, only in SEM.
Edit: 06 Sept 2022, fix broken link for spiracle filled with dense mat of filter hairs
