The video.
Took a trip to the river and came back with 2 gallon jars of sample water from a shallow backwater area. I needed to recharge my microbe aquarium.
1. 10x.
2. 10x.
3. 4x.
4. 10x.
5. 10x.
The objective image, when focused at the right distance, is formed 10mm below the end of the eyepiece tube or photo port. If you use Nikon CF objectives (no need of eyepiece corrections) direct projection is a real alternative, but you need to modify the photo tube to place the camera sensor at this position. It may be done if the tube itself can be dismounted and you can cut it (well best to make a new shorter one). In a Canon DSLR the sensor is placed 44mm behind the lens mount "flange focal distance", so you need to place the camera mount 54mm lower than the phototube end.Mitch640 wrote:I did just do a test though, using my micrometer scale. The good news is, I can get good focus, full frame, with no PL lens at all. The bad news is, it is nowhere near parfocal anymore. Here's a couple of shots and more testing will be needed.
If I understand this right, that would be impossible. I would have to cut the trinocular tube off the head???Pau wrote:- The DOF only will change if the magnification (or NA) changes
- Shorter would be beter, but still not parfocal, to be parfocal the sensor plane need to be placed 10mm bellow the end of the tube where the photoeyepiece sits.
Yes, this is what I tried to explain in my first reply. If the phototube can be dismounted, a shorter replica can be made, and a test with a bellows or extension tubes set holded in its place would be performed. (Perhaps possible, surely not easyMitch640 wrote:If I understand this right, that would be impossible. I would have to cut the trinocular tube off the head???
