Sawfly Saws - how they work
NikonUser
Post by NikonUser »
EDIT was "Another "What am I?""
Part of a part that is part of an insect.
40x Splan Apo + 2.5x relay lens
NU11050
NU.
student of entomology
Oliver Wendell Holmes, Sr
lauriek
Post by lauriek »
A wasps tongue? (or whatever the proper entomological name for that thing they stick out like a tongue is!)
Post by Mitch640 »
The trailing edge of a wing?
Looks more like stretched out skin of something.
NikonUser
Post by NikonUser »
No, not a tongue, not a wing, not stretched.
With 20x objective:
NU11051
NU.
lauriek
Post by lauriek »
A bee stinger?
NikonUser
Post by NikonUser »
No, not a bee stinger.
Another image tomorrow.
NU.
NikonUser
Post by NikonUser »
10x and 4x
length A-B = 2.0 mm
Correct orientation, top is dorsal, A is posterior.
Give-away clue: insect is named for this 'apparatus'
NU11052 NU11053
NU.
Post by Planapo »
A sawfly's "saw" i. e. ovipositor?
Makes a beautiful 'graphic' image by the way!
--Betty
NikonUser
Post by NikonUser »
Thanks Betty; correct ID of course.
There is a pair of these saws within the sheath seen below; C-D is only 1.6 mm and the saws extend further back into the body.
Unfortunately I did not pay sufficient attention when I dissected out the 'apparatus'. I may have dorsal and ventral reversed.
:roll:
NU.
Post by Mitch640 »
Never would have guessed, cause I have never heard of a sawfly.
I would be curious though, to test a real steel blade with this exact shape ground into it, to see how efficient it is as a knife. It's already got a hollow ground edge on it. :)
NikonUser
Post by NikonUser »
Engineers can learn a lot from nature; which I'm sure they realize.
The darker the brown = thicker and stronger tanned cuticle.
Back of the blade is the most rigid, bands of thick cuticle run down from the back to end in the cutting edge which also seems to be supported by long triangular points.
The clear cuticle between the saw-edged teeth would be thin and flexible.
I think it's the top 4 images that do the sawing.
NU.
lauriek
Post by lauriek »
Lovely wider shots NU. (And I wasn't _too_ far off with the bee stinger, right order and area of body anyway!) :)
It looks to me as though someone designed the electric carving knife based on these...
Post by Mitch640 »
That's where I've seen this. An electric fish filet knife I once had. :)
NikonUser
Post by NikonUser »
lauriek wrote:Lovely wider shots NU. (And I wasn't _too_ far off with the bee stinger, right order and area of body anyway!) :)
Thanks Laurie.
I purposely made no comment, it would have been too much of a clue.
NU.
