Following 4 pictures are Geotrichum Candidum (grown on Malt Agar), this mold you can find on the surface of some stinky cheeses.
Fluorescence microscopy, dye – Calcofluor white (stain chitin, thus you can see only cell walls and septa), Objective - Carl Zeiss Jena 40x 0.95, 550 EOS, ISO 200.
Important that pictures were obtained using NO common expensive epi-fluorescent attachment.
I used just two interference filters (eBay) and as a light source – 10W UV LED (eBay), everything was not more than 150 USD, what is incomparable with cost of the common epi-fluorescent attachment.
Optic scheme was very simple: UV LED with cooler - collimator (metal, not plastic) - excitation filter (365 nm) - condenser-sample – objective - barrier filter (450LP)….see following picture.
How I have found recently, power of such LED was enough to excite even autofluorescence of xylem lignin which does not require (by determination) any dye addition.
