These look very good Mitch.
You can focus with the regular screen, until it looks right on, then switch to zoom view and you see it's still way off.
This is why it is so desirable to have some method for continuous fine adjustment (up/down) of the camera when initially setting up your microscope. If you can do this, you can use the magnified "live-view" to adjust the camera height and make the camera very accurately parfocal with the viewing eyepieces. Once this is done you can confidently achieve very accurate camera focus through the viewing eyepieces. For static (or very slow) subjects focusing off of a magnified live-view screen image is no problem, and very effective. But if you chase active critters around a slide (and use electronic flash), you really do want the camera focus to always be a dead-on match for the viewing eyepieces. In these instances you simply do not have the time to check a magnified screen image.
(And somewhat counter-intuitively, your depth-of-
focus...
the amount of "leeway" you have at the sensor location... is very much less at low magnifications. So when setting up the position of a camera on a microscope it is best to use a 4X or 10X objective)
