A 'non-Cyclops' Copepod
NikonUser
Post by NikonUser »
The Copepoda (subclass of the Crustacea) has 4 freshwater groups with the short, stocky, Cyclops in the Order: Cyclopoida and some more elongated forms in the Order: Harpacticoida.
Collected this harpacticoid yesterday in a tiny stream that was flowing with snow-melt.
This is a female with a sperm package (spermatophore) on a long stalk that is attached by the male into the females's genital opening.
The blue/green colour is from a stain.
Top: 10x Nikon CF N Plan objective on bellows; reflected light.
Middle: 10x Oly SPlan Apo + 2.5x relay lens; transmitted light; 49 frames @ 4µ, ZS PMax; Nikon D90
Bottom: actual pixel selection showing spermatophore and 5th leg.
[ZS PMax is incredible software.]
NU11027 NU11028 NU11029
NU.
student of entomology
Oliver Wendell Holmes, Sr
NU,
Interesting subject. And very nicely photographed and presented!
Post by Mitch640 »
Excellent work. I am going to have to learn stacking, now that I have clean glass to take them with.
I have not seen this subclass in my tank yet. They are quite different, even to me.
NikonUser
Post by NikonUser »
Thanks Charles. These beasts apparently are rare in NB, a recent paper on the Subclass: Copepoda mentions only the Calanoid Copepoda and the Cyclopoid Copepoda.
Thanks Mitch. At first glance these resemble small Amphipods (shrimps), they swim 'smoothly' unlike the 'jerky' swimming of a Cyclops.
That complex structure of the 5th leg seems to be a defining feature for the harpacticoids.
Stacking is essential for any specimen that has depth; only problem is the specimen must not move. Otherwise, using ZS there is nothing to learn; just take a series of images and ZS PMax does the rest.
NU.
Post by Mitch640 »
One thing I have plenty of is Cyclops. The shrimp I got shots of the other day has gone back into the tank. He is hunting and eating Cyclops and has visibly gained size, just since the other day. I will watch for any suspicious looking 'pods.
Song miae
Post by Song miae »
I love these pictures ! :D
Blue color is very beutiful and wonderful !
I thought that green color is green algae. But my mistakes !
I love taking pic. And all of the algae.
NikonUser
Post by NikonUser »
Thank you, Song miae.
Many aquatic arthropods have a clear cuticle (exoskeleton), it is easier to see details when this cuticle is stained.
NU.
realjax
Post by realjax »
Lovely images! I know nothing about staining but would love to learn more, any idea where I can find more info?
Jacco
Post by Mitch640 »
Jacco, being in Europe, you are in luck as far as buying dyes and stains. After a lot of searching about the subject here in the US, I found that all the good supply places are in the UK or Europe.
NikonUser
Post by NikonUser »
Arthropod cuticle is notoriously difficult to stain.
Acid Fuchsin and Chloral Black E are reputed to be excellent stains for arthropod cuticle. I am far from up-to-date for use of these. I'm sure if you Google "Staining Tecniques" you will find lots of information; there are books written on the subject.
Several stains have antibiotic properties and are used as disinfectants and such stains are taken up by cells.
The easiest source for these is a pet shop that sells tropical fish supplies.
Any chemical (with a colour) that is sold to kill fish parasites such as White-spot disease is worth trying. Old-fashioned chemicals were Methylene Blue, Methyl Green and Crystal Violet.
My local Wal Mart sells "Ick Guard"; the active ingredients being a blue dye (Victoria Green ?) and nitromersol. Dark blue stain that I used for the copepod. Simply soften the arthropod parts in 5% NaOH or 5% KOH overnight; thoroughly rinse with water to remove the alkali and then soak in a drop or two of stain until desired colour is obtained. If too dark (unlikely), a very weak alkaline soln (<1%) will remove excessive stain.
NU.
realjax
Post by realjax »
Thanks for the info. Not sure if I'm ready yet to stir up some alkali though. :) But I'll check out my local pet shop!
Jacco
NikonUser
Post by NikonUser »
Jacco,
I doubt if any stains will work unless you soften the cuticle. The wax layer on insect cuticle will likely resist the penetration of any stain. Aquatic arthropods may be easier to stain.
NaOH is a dangerous chemical. It is sold over here in pellet form for opening blocked toilets. One pellet in about 50 mL of water is reasonably safe to handle and should work. Low cons. work better (and slower) than higher cons. So, perhaps work with a very weak soln. and let the arthropod soak for 1-2 days (trial and error process).
NU.
