Leitz Ortholux microscope
4X Leitz projection eyepiece plus 1/3x relay lens
Image No.1
Horizontal Field of View - 10.25 millimeters
16 images at .005 inch increments
Nikon 1.2x Plan Achromat objective
Diffused Fiber Optic Illumination
Image No.2
Horizontal Field of View - 3.3 millimeters
13 images at .002 inch increments
Leitz 4x Plan Achromat objective
Image No.3
Horizontal Field of View - 700 micrometers
165 images at 1 micron increments in area of interest, then 2 microns
Leitz 32x UO Achromat objective, iris full open.
Polarized Diffused Fiber Optic Illumination
Canon 50D
Zerene PMax and Photoshop 7 processing.
Normally, looking at a rock under magnification is not very interesting. However in the case of this Ordovician sea floor sample I have run across two interesting micro subjects.
The first, and undoubtedly most interesting, are the small round black objects visible in these images. I was about to dismiss them as once non-living crystal formations, until I noticed that they all had a single tiny hole in their centers. I don’t believe that a crystal would grow like that. They are scattered about and seem to have some relationship with another odd repeated feature, the green patches nicely visible in the upper and lower right of image three. The green spots may be the base elements of broken off black objects.
The black subjects range in diameter from 100 to 170 micrometers. The subject in image three is roughly 170 micrometers and has a 10 micrometer hole in its center. Polarized light was used to provide as much detail on its surface as possible. The green spots as well as the black objects are on a surface of fine mud, now crystallized that is made up of fine calcium carbonate crystals secreted by marine algae of the period. So this is not sand.
I hope the learned members of this form can tell me what species of extinct animal these are.
Walt
