Alectoria ochroleuca
ralfwagner
Post by ralfwagner »
Hello,
Alectoria ochroleuca is a lichen that can be found in alpine heathlands on acid soil. This one is from Tyrol, Austria.
- Thallus, 8 - 12cm , erect or sprawling, modeerate branched, branches up to 2 mm diameter, yellowgreen to bright green. Apex often black. Elongated, bright pseudocyphellae, often black pycnidia at the apices. Chemistry: Medulla: CK + yellow (diffractic acid), cortex: KC+ yellow (usnic acid).
- Closeup thallus with longish pseudocyphellae. 25 pictures stacked with Zerene stacker.
- Closeup apex with black pycnidia. 30 pictures stacked with Zerene stacker.
- Cross section branch. In contrast to Usnea there is no (compact) central axis with Alectoria; staining with Lactophenol-Methylblue-Acidfuchsin.
BJ
Post by BJ »
Ralf,
I particularly like the third photo as it has a good 3D feel, with the lichen standing out from the background.
In my ignorance i would have definitely called it an Usnea !
Is the lack of central tissue a clear discriminator between the two genera....and is it obvious in the field if you just cut through a branch ?
Thank you for posting again!
regards
Brian
Post by Mitch640 »
Very nice images, even if I don't know exactly what they are. :)
ralfwagner
Hello,
the lack of a central tissue is the most obvious and clear discriminator between Alectoria and Usnea.
This an example for Usnea:
Usnea fulvoreagens, cross section branch, oblique ill.
Usnea fulvoreagens, cross section branch, phasecontrast
In the field this can be easily examinated with th aid of a magnifying glass (10x).
Thanks for your kind comments.
Ralf,
I find the last two images in your initial post not only informative but aesthetically quite pleasing!
