Leitz Ortholux microscope
4X Leitz projection eyepiece plus 1/3x relay lens
Image No.1
169 images at 5 micron increments
Nikon 10x Achromat objective
Diffused Fiber Optic Illumination
Image No.2
67 images at 5 micron increments
Cropped image.
Image No.3
62 images at .001 inch increments
Leitz UO 6.5 X Achromat ULTROPAK objective
Canon 50D
Zerene and Photoshop processing.
As if some spiders weren’t hairy enough, this grass spider Genus Agelenopsis is blanketed with fine plumose hairs. They appear as fine fir tree like features seen amongst the spine like hairs. The images above are a, millimeter or so wide, section of the tibia leg member of Agelenopsis pennsylvanica. I don’t know if these are unique to this genus or not. As small as they are, about 36X magnification is needed to see them, they are missed using even a loupe.
The plumose hairs are found on the legs and elsewhere, even on the abdomen. If you care to look at my earlier post, Spiders No. 21, this is the same spider and more plumose hairs are faintly visible there. You can see them in the darker shaded area in the upper right section of the lower image.
Walt
