Here's the video of the blob.
Microscope: Nikon Fluophot Flourescence Research Microscope
Camera: Canon T1i w/ EOS Extension Tube adaptor w/Nikon 2.5X Projector lens
Scope Settings: 15.1 MP Canon 1.6x Camera over 40x Objective
Ferry, thanks for the advise. I will do some tests for that, cause as you can see, color aberrations are giving me fits. I still do not know if it is caused by cheap glass or some other problem I know even less about. I seem to have sharpness issues with this E 40x lens also. If my better quality 20x Plan Apo ever gets here, I can maybe find out.I have the impression that you close your field diaphragm a little to much, which makes the picture more unsharp than needed; you get to much diffraction and color shift.
The entire advancing, usually hyaline, anterior end of most amoebae is functionally a single lobose pseudopodium or succession of single pseudopodia, but many more or less compressed amoebae produce, ususally from the hyaloplasm, narrow, even fine projections, called subpseudopodia. Most have no demonstrated function. They may be blunt, digitiform, mamilliform etc. They don't take part in the locomotion of the amoeba, like the pseudopodia. Mayorella has typical mamilliform subpseudopodia.NikonUser wrote:My text separates this family from the Amoebidae by the presence of subpseudopodia; Amoebidae lack subpseudopodia.
I have no idea what they are, leave you to work it out
