Dave,
The 20/0.80 D Plan Apo UV is extremely sharp and bright, but it has one significant "issue". On certain bright edges it shows an unusual looking red/cyan color aberration that is tough to correct. I've experienced it with two different samples, and have communicated with Rene, and he has experienced the same thing with other samples. Too bad, because it provides an incredibly bright, sharp, viewing image. Here's a small part of the first stentor image. You can see what I'm talking about.
As far as resolution goes, I'm primarily after a good overall picture, so I don't necessarily pull out all stops in order to get the best resolution possible on a single detail (I generally need a little more DOF than that would yield). The 60/1.40 is an excellent good objective, and with that NA the very best I could ever hope for is a resolution of about 0.25 micron. Here's a small section of that second stentor shot (converted to b+w) with a few pairs of bars. The shorter bar represents one micron, the longer bar two micron. So I guess it's not too shabby.
