Used this 60x on an Olympus microscope with an Olympus 2.5x NFK relay eyepiece.
Smallest Desmid I could find was actually too large for the 60x and 2.5x relay lens on a (23.6 mm sensor); but I wanted to try and see what this lens could do with a less than optimum setup (but it's the only one I have).
7 RAW (Nikon NEF) frames @1µ, corrected for white balance and chromatic aberration in CS5, converted to jpg's and stacked with ZS PMax.
I suspect the clear halo around the desmid is a layer of mucilage.
This lens is obviously usable for reduced-sized images.
Top: full frame
Middle: actual pixel selection
Bottom: cloned image
NUM10107
