Thanks Rik.
A few words about this diatom and about workflow.
This slide is slide no. 33 from my boxed diatom slide collection,
Mors, Jutland: Fossil Marine, Flatters & Garnett 1954, styrax mountant. A little scouting around suggests this is
Trinacria sp.
The Diatoms, Round, Crawford & Mann, 2000 say
Cells tri- (quadr-)angular, attached in chains by the extended apices. A marine, fossil genus occurring in the early Eocene.
In respect of workflow:
The stack was shot using flash to minimise vibration. When not using live view, vibration can be seen visually when the shutter is released, but I prefer to use flash for this type of work.
The increments were manually judged because they were too fine for easy setting using the fine focus markings.
The images were pre-processed in Helicon Filter for white balance and dust map.
Post processing was in Paintshop Pro X2 for contrast enhancement, cropping and resizing for publishing. I applied a low level of sharpening on resize.
The cropping was done by cutting one image and pasting it as a new layer over the other and then cropping. The canvas was then resized and the top layer placed to one side of the bottom layer to give the correct layout for the stereo pair again. The layers were merged and the final image trimmed and saved.
