What's the technique used to take this image?
Pau, I am curious what went wrong when you tried to stack this. Sometimes at high magnification things go OOF in strange ways that cause nasty artifacts, like bad alignment or dimples and rings on what should be smooth spheres. Looking at how areas go OOF in just this one frame, I don't see anything that I would expect to cause problems. But perhaps this frame looks well behaved only because everything is either focused or behind the focus plane, and the bad OOF behavior appears only for objects in front of focus.Pau wrote:This image is an unexpected result of my failed attempt to make an high resolution stack of this diatom. It's a single shot of a serie of 17. After spending an huge lot of time cloning out lots of dust spots, the stack was horrible but some frames like this one had a nice focused part
Yes indeed, dust is just brutal with high mag objectives... dust that is no problem at all for "normal" photography. The camera I use on the microscope was in real need of cleaning (similar to what yours shows in the full shot, but with an additional one or two much bigger blobsAfter spending an huge lot of time cloning out lots of dust spots, the stack was horrible
Any idea why? Generally subjects like this stack pretty nicely. (At the very least for a few frames until the "back" side starts showing through). Did you try it with all "adjustments" turned off? You usually don't want them at these magnifications. (And there are also no dust "tracks" to deal with then as well)the stack was horrible
The problems were all you say plus bad alignement of some of my dust corrections (I did clone the dust in each image, a big mistake)rjlittlefield wrote:Pau, I am curious what went wrong when you tried to stack this. Sometimes at high magnification things go OOF in strange ways that cause nasty artifacts, like bad alignment or dimples and rings on what should be smooth spheres. Looking at how areas go OOF in just this one frame, I don't see anything that I would expect to cause problems. But perhaps this frame looks well behaved only because everything is either focused or behind the focus plane, and the bad OOF behavior appears only for objects in front of focus.
Just to check, what happens if you process in Zerene Stacker using PMax, with scale adjustment turned off and maybe even Shift X and Shift Y turned off?--Rik
I'm allways surprised -and pleased- with the cleanness of your photomicrographies, and I now also appreciate your skills removing dust. Some advice (or mini tutorial) on this topic would be extremelly useful. I only clean my sensor with canned air (at some distance to avoid condensation). Would a wet cleaning manage this microscopic dust particles?Charles Krebs wrote: Yes indeed, dust is just brutal with high mag objectives... dust that is no problem at all for "normal" photography. The camera I use on the microscope was in real need of cleaning (similar to what yours shows in the full shot, but with an additional one or two much bigger blobs). ...
....Any idea why? Generally subjects like this stack pretty nicely. (At the very least for a few frames until the "back" side starts showing through). Did you try it with all "adjustments" turned off? You usually don't want them at these magnifications. (And there are also no dust "tracks" to deal with then as well)the stack was horrible
