On a microscope slide, added one drop to a drop of water containing the rotifer. This stopped the rotifer from swimming but did not stop its toes from moving (nuisance) and did not stop its feeding action.
It appears that the Protoslo did not completely mix with the water and at least one 13.6µ droplet existed.
In this stack of 27 frames this droplet (bottom of image) can be seen in its curved course to finally enter the rotifer’s mouth. Another current is apparent on the upper surface.
This is an artificial situation in that the rotifer was constrained between a microscope slide and a cover glass.
Olympus 20x S Plan Apo, NFK 2.5x projection eyepiece; 27 frames @ 2µ, flash, full frame; ZS P Max stack
NUM10083
