This is actually a combination of darkfield and (partial) crossed polarizers.
Taken with the 20X. The test, as seen here, measures 0.34mm wide and 0.28mm tall (0.013x0.011 inch).
Can you explain a little your technique?. A normal darkfield stop plus cross polars or something combined?Charles Krebs wrote:This is actually a combination of darkfield and (partial) crossed polarizers.
I photographed the same "view" in both darkfield and then (partially) crossed polarizers. They looked remarkably similar (there was no birefringence that "lit up" with polarization), but on the subject, the "edges" were more transparent than the center. While I liked the darkfield better overall, the polarized version showed the edge detail better. So I simply layered the images in PS and used the "best" parts of each.Can you explain a little your technique?
