First image is with 4x objective, the last two are with 10x objective (the last one is a crop of the previous one). All with direct projection on Canon 7D (because of the mechanical problems the sensor is further away from where it should be, so the real magnifications are higher I believe).
Used a single flash (Canon 430EX II) with a half ping-pong ball diffuser. Zerene stacker, light room for tweaking.
You can check the higher resolutions here
