A Bulbochaete alga
NikonUser
A Bulbochaete alga
Post by NikonUser »
EDIT: was "Alga ID appreciated"
From a local lake outlet,
10x, 20x, and 40x Olympus objectives; all with NFK 2.5x photoeyepiece. ZS PMax stacks
NUM10023 NUM 10024
NU.
student of entomology
Oliver Wendell Holmes, Sr
rekuwi
Post by rekuwi »
Hallo NU,
may be Bulbochaete (mirabilis)
(Kosmos Naturführer: Das Leben im Wassertropfen von Heinz Streble/Dieter Krauter, Page 191)
greetings
Regi
Will Milne
Post by Will Milne »
Hi NU
I've always enjoyed your work both non scope and the new scope adventures. Have no idea on an ID :) but was curious if you have done any imaging with your new scope using nikon cf's and direct projection versus oly objectives and the photoeyepiece ? Nice images.
Will
NikonUser
Post by NikonUser »
Thanks for the ID Regi. I'm sure you are correct.
Found this on the WWW
"This branched, filamentous green alga is named for its distinctive, colorless hair cells with bulbous bases. The filaments have more than six cells, are unilaterally branched in a single plane, and lack mucilage. The cells are broader at their upper end and each have a parietal, net-like chloroplast with several pyrenoids."
REF HERE.
I wish I had paid more attention to those Hair Cells.
Thanks Will.
No, I haven't used the Nikon CFs on the scope. I have only a 4x, 10x, and 40x (E). Although all 3 were designed for transmitted light and a cover glass the 4x and 10x work well with reflected light and no c/g.
I can't see any advantage of using the 4x and 10x on the BHS, - don't I get the same result by using them on bellows? Is there an advantage?
It may be worth checking the 40x on the BHS with direct projection. The BHS does have a nice substage condenser. Up until now I have used the Nikon 40x on my modified Oly BHM base, no condenser and flash beneath the stage.
NU.
