Volvox
NikonUser
Volvox
Post by NikonUser »
9 views of a single live, very active, Volvox.
How do you keep these beauties still?
Oly S Plan 10x, 2.5x photoeypiece; flash; all single exposures.
A younger Volvox
Oly 20x SPlan Apo + 2.5x NFK photoeyepiece 23 frames @ 5µ ZS PMax stack
NUM10061
NU.
student of entomology
Oliver Wendell Holmes, Sr
NU,
Very nice!
Craig Gerard
Post by Craig Gerard »
NU,
Excellent presentation! Very 'clean' images.
What is the black background that appears in some of the shots?
Have you ventured into darkfield yet?
Not easy... lots of flagella at work there! :wink:
Best bet is the time "window" when the water has evaporated from the wet mount sufficiently to drop the cover slip so it just holds the "colony" in place but does not distort it much. You can play around with the water depth by having an absorbent tissue and an eyedropper of pond water handy. When you touch the tissue to the edge of the coverslip it will absorb some of the water and "lower" the coverslip. Don't overdo it or you'll crush large subjects. Add a little water from the eyedropper to the edge of the coverslip/slide if things start getting flattened too much.
These are magical to observe in darkfield... simply beautiful!
ABEL
Post by ABEL »
Very nice photos.
Volvox is my hanging subject. It seems to be incredible but I have never seen a volvox :roll:
NikonUser
Post by NikonUser »
Thanks to everyone for the responses.
Craig: black= edge of air bubble; not yet into darkfield.
Charles: haven't had much luck using just the water film to space large objects (e.g., Volvox) (another oxymoron!),evaporation is rapid with explosive results.
Have tried your Vaseline spots as risers, too messy.
Today I bought 2 sets of feeler gauges planning to use them as spacers beneath the cover glass.
These feeler gauges come in various thicknesses, mine are 0.038 mm, 0.051 mm, 0.064 mm. 0.076 mm, 0.102 mm, 0.127 mm, 0.152 mm, and thicker all the way up to 0.635 mm, 26 in a set.
I have 0.17 mm and 0.2 mm cover slips which can also act as spacers.
Abel: when you first see Volvox under a binocular (dissecting) microscope it reminds one of a space ship rotating and hurtling through space - they are fast.
Many years ago I used a chemical that was isotonic with water but was more viscous and slowed down Paramecium; anyone any ideas what it could have been?
NU.
NU,
You are referring to methyl cellulose.
There's at least one commercial product designed to do exactly what you intend... Protoslo (Carolina Biological Supply)
NikonUser
Post by NikonUser »
New image added
NU.
Post by Mitch640 »
The new image is a beauty.
I bought some methyl cellulose, but haven't used it yet. It's thick and clear, like a light oil. I have read that to use it, use a toothpick to spread a circle of the liquid under where the cover glass would go, then add the drop of water, then stir the water and circle of methyl cellulose together, then cover it.
Let me know how you prepare it, cause I only know what I have read. So far. :)
icecilliate123
consider mail purchase of 1.5% methyl cellulose, Mitch.
Post by icecilliate123 »
Hi Mitch, wonderful images of Volvox, thanks for this eye-candy.
Please purchase ready mixed 1.5% methyl cellulose. It's there next to your alcohol drop-bottle, next to your optical immersion-oil bottle, in with your other microscopy kit. A 1oz bottle keeps well for a few years if you don't contaminate this stock by back and forth contamination from the same applicator toothpick! You can find it at many online stores ( I use Home- sci, 'Elemental scientific, Appleton,WI, or Wards Sci, etc. .).
Thanks for your shared microscopy, Mitch.
charlie guevara, fingerlakes?US
icecilliate123, welcome back. Thanks for the information about methyl cellulose.
By the way, it seems you were reading or writing too fast again. The Volvox images are from NikonUser, not from Mitch.
BJ
Post by BJ »
Nikon User,
Great series of photos- beautifully clear - thank you !!
Mitch,
I think i may have posted this some time before in relation to carboxymethyl cellulose (which is more or less the same thing). What I do is place a drop of sample on the slide and then place a drop of carboxymethyl cellulose next to it (not necessarily touching). Then put the coverslip in place without mixing the two together. This will create a gradient of methylcellulose (and therefore a gradient of viscosity) across the coverslip. Then if you have several specimens, some will not be slowed at all, others are slowed to varying extents and some are completely stopped.
Try this and see if it suits you.
Good luck
Brian
NikonUser
Post by NikonUser »
Thanks BJ
Mitch: I have not answered your question re: methyl cellulose as i am still waiting on delivery from the USA :(
BJ's method sounds good.
NU.
Post by Mitch640 »
That's an excellent idea Brian. I will try that. I am waiting delivery of a new video camera, [Monday], and that seems like a good time. :)
NU, I still haven't tried it myself. :)
By the way, I am still waiting delivery of some small sample dishes, also from the US. :(
Gallery14
Post by Gallery14 »
NikonUser, could I use your 9-view photo for a design project (with the appropriate credit given)? More in pm.
Nina
