HERE
but this is in the genus Centropyxis
Olympus BHS, 20x D Plan Achromat, 2.5 NFK photoeyepiece; flash; ZS PMax.
Width top to bottom, excluding 'spines', 0.22 mm
Shell is very dense and reaches a high region in that very fuzzy region; I suspect there is some protoplasm in this area.
NUM10007
Testate amoeba, on slide in water under cover glass.
20x Oly D Plan with top lighting from a single flash from the side.
Question: would I get a better image with a Oly M Plan objective. I believe M Plans are designed for no cover glass but would the image be sharper with an M Plan and such a specimen under a cover glass?
NU10009
