Salamis parhasssus wing scales
These wing scales were photographed at 125X on sensor. From (ZS) stacks of 31 and 48 images respectively.
Olympus BHA, 50/0.80 M SPlan, 2.5x NFK photoeyepiece, BH2-UMA vertical illuminator, Canon DSLR. Polarized brightfield.
Wonderful images -- the bar for moth/butterfly scales just keeps going up!
I wonder, what do scales of more "ordinary" species look like with this magnification and lighting?
Have you tried anything more widely available, like say cabbage or sulphur or tiger swallowtail butterflies, or some of the more common moths like the Alfalfa Looper?
Craig Gerard
Post by Craig Gerard »
Beautiful!
Charles,
Wow, beautiful.
Now I know what can be done.
scitch
Post by scitch »
Wow!
Charles,
I would like to know the step size that you did use for this spectacular images.
Rogelio,
The stepping on these was done "by eye" while viewing through the eyepieces (with the microscope light split between camera and eyepieces).
I can't do it by looking at the marks on the fine focus because the steps are too small. The DOF should be a little less than 1 micron at this magnification and NA, so the focus steps are probably in the 0.5 to 0.7 micron neighborhood. (In terms of angular rotation of the fine focus knob that correlate to about 0.9 to 1.2 degrees of rotation per step... if I calculated it correctly!). Each "tick mark" on my fine focus is 2 micron, so I could do 1 micron steps by viewing the scale with some confidence, but not really any smaller than that.
Will Milne
Post by Will Milne »
Hi
Stunning images Charles!!!!! I'm curious having looked at your work as a source of inspiration and as " this is where I would like to go " , when you say "brightfield " is this substage transmitted or epi type brightfield illumination? .
Will
