This is the common house spider, tegenaria domestica. It's also the first test of my new microscope stage and Nikon U5. I have seen some discussion about this objective, but I thought I'd give it a go. It has a diaphragm, which makes it useful for field work, but for microscopy I have used it wide open. Seems to resolve OK, about on a par with the Luminar 25mm, though the contrast is slightly better
and here are the jaws of the same animal taken with a nikon 10xDIC 160-
The resolution of this objective is great, with huge contrast. Both objectives attached to my now unrecognisable Lomo using direct transmission rather than a photo relay.
Both stacked using ZS, about 90 images each. Scary for smaller things, I should imagine....
Jules
