Point and Shoot Lichens
I have admired Nikolas work with the Olympus point and shoot cameras for some time now, well ever since Nikola joined our forums as a matter of fact. So, anyway, I decided I would give my little Sony DSC-W1 five mega pixel a try at macro, since it does have a macro mode. I shot these photos in the manual mode. In manual the Sony gives me only two apertures f/2.8 and f/5.6 to work with and with a wide range of shutter speeds up to 1000 sec. The following images were shot at 1/250 sec. @ f/5.6 and I used two pieces of frosted scotch tape over the flash lens to work as a diffuser. I was very pleased with the results I got from the Sony but it is quite clear that the Olympus camera(s) employed by Nikola are much better. Just the same I am still quite pleased with the result obtained from the Sony DSC-W1. :)
By the way, those are not myxomycetes growing on the stem, in the upper left hand corner of the second image, they are however, some sort of orange colored jelly fungi, I think. :-k I did not even notice them until I began processing the images this evening. :D
I think they are rather good shots Ken. Like you said...you can see the jelly fungi on the branch :wink:
Thanks Doug :D, I do like the results I got from the camera and to tell the truth a camera such as this is much easier to work with in the field because of its weight and size, unlike the Canon dSLRs that I also use and I can easily attach it to my belt or toss it into my backpack when out hiking the mountains and come across a subject that I would like to have a close up of and don't have the time to fool around with a bunch of equipment, also when out hiking these mountains, weight is a major consideration of the gear you carry or you are going to have one miserable day hike. Of course if you are married or single and have a girlfriend along...then she or the wife, which ever the case may be, can or could carry the extra gear for you! :lol:
Great shots, Ken. :D The Sony cameras are quite fine. I must try that flash setup.
Ken Ramos wrote:... Of course if you are married or single and have a girlfriend along...then she or the wife, which ever the case may be, can or could carry the extra gear for you! :lol:
No wife (dSLR) here, just three girlfriends. :lol:
Besides, wifes are, usually, tending to get weighty. :shock:
Thanks Nikola :D The frosted scotch tape does make a good flash diffuser and it is not noticeable or in the way when you are shooting and can be easily removed when not needed. The idea came about when I was getting really blown whites in the auto or priority modes. :)
Roy Patience
Post by Roy Patience »
Ken,
I enjoy looking at your images of the plants that grow in the moister areas of the country. I don't see many lichens here in Southern California.
My favorite flash diffuser is a small piece of white, translucent plastic grocery bag wrapped around my flash and secured with a rubber band. It might be worth trying if you want more diffuse light than the tape diffuser.
Roy
