Hi there,
I found this beetle in my garden yesterday. It's a stacked image, but this time I used some moss from the garden to mock up a real scenario.
D200 with Sigma 150mm macro lens + 1.4 X teleconverter
1/250 sec @ F8 Iso 100
Frames stacked in Helicon focus
Finished in Photoshop.
Violet Ground Beetle (Carabus violaceus)
- georgedingwall
Last edited by georgedingwall on Sun Mar 02, 2008 2:18 pm, edited 1 time in total.
George,
This is very nice! The use of moss as a background not only gives the scene a natural look, it also protects you from halo artifacts around the edge of the subject. The lighting here is very contrasty and dramatic. It seems clear from the black blacks that you've either gotten flare under control in the shooting, or you've level-adjusted it away by postprocessing. Just personally, I would rather have some detail visible in those shadow areas. Is there any way you can pull some light around to the front? Perhaps some crumpled aluminum foil surrounding the lens (but in back of it to avoid flare) would help out here.
- georgedingwall
Hi Rik,
I enjoy trying to get a "realistic" feel to an image.
I've tried your suggestion and bounced some light in through the front of the diffuser. I also re-positioned one of my lights to try to force a bit more light on the underparts.
I couldn't find another sample of moss with the nice feathery feel to it but I re-shot a sequence to see the effect of the altered lighting setup.
It's had quite effect on the head area. The underparts have also got some detail on them. I think the moss in blocking too much light to overcome the power of the lights on the upper parts of the beetle. Maybe if I had a fibre optic light I could force some light into a place like this without overexposing the rest of the image. But that's for another day - maybe a Christmas present.
Anyway, here's the re-shot image showing the effect of the altered lighting setup.
Bye for now.
Thanks for the comments.rjlittlefield wrote:George,
This is very nice! I would rather have some detail visible in those shadow areas. Is there any way you can pull some light around to the front? Perhaps some crumpled aluminum foil surrounding the lens (but in back of it to avoid flare) would help out here.
Bye for now.
Last edited by georgedingwall on Sun Mar 02, 2008 2:19 pm, edited 2 times in total.
- georgedingwall
