If some of you wonder why the photo looks sort of red, well this is the south..."red clay."
He replied "I don't know the mechanism, but surmise it to be as you suggest."Fascinating! Do you know what the mechanism is? I can only speculate that this occurs at "seeps", where in warmer weather water slowly flows up out of the ground and then runs off the surface. Below freezing, I suppose, it cannot run off and instead gets pushed up by new water rising from below?
No idea for a name. This phenomenon is common up here in Canada. My understanding is that when the ground is at just about freezing and then the air temperature drops, the water in the surface layer freezes.Bruce Williams wrote:Ken - I'm amazed - this is a completely new weather phenomena to me. Is there a common name for what you've photographed?
Bruce
