Irwin
I have no doubt that when you get your dedicated macro lens you will be feel comfortable with it quickly. The improvement in your images in the past month or so makes it clear that you are ready for this step.JoanYoung wrote:Glad to see you are back Irwin and hope you enjoyed your holiday. I was contemplating getting the G9 also but decided to go with the 400D, but it will be a while before I post pics taken with it.
I don't know why Canon priced the G9 like it did but I am glad. I love that you can shoot in raw, in fact I just love the camera..Ken Ramos wrote:I have the G7 and so far have had nothing but excellent service from it. I was surprised however to find that the G9 is around a hundred dollars or a little more less than the G7. I figured with such a sharp drop in price, something somewhere had to have been sacrificed but I guess not. Wonder why the sharp difference in price between the two? Still I would not give up my G7, very portable and very good at producing sharp images. By the way, I put my G7 on a Novoflex camera flash bracket with the Canon 430EX ETTL speedlite and off camera flash cord. The bracket makes for using the 430EX flash a lot simpler with the G7, since the flash is as big as the cameraand also positions the flash much better over the little G7 for macro shooting.
Shoot Joan, I think you gave Ken a swollen head just before the New Year. What does this portend?JoanYoung wrote:You should let Ken give you some advice Irwin, most of his recent stuff is taken with his G7 and they are brilliant. (Just don't tell him I said so....he might get a swollen head from a compliment like this!!)He also always adds his exif data to the pics, so you can browse back and look at them. Mostly he uses manual mode.
Irwin, there should be no problem using Photoshop's Save As to create jpeg for upload.cactuspic wrote:I have tried to resize the image and reduce pixel count to 800, use the save as function, and then post. But it usually spits it out and tells me I have exceeded my image size. So then I have to knock down the image quality in the save for web setting.
Well, that's odd. I don't have a Mac to test on, but none of the literature I can find indicates that there's any difference between Mac & PC. On my PC, running Photoshop CS (Version 8.0), here's what happens. I select File | Save As and get a filechooser dialog titled "Save As". Within that dialog, I select Format: JPEG. Then when I click the Save button, another dialog pops up, this one titled "JPEG Options". The JPEG Options dialog has a block labeled Image Options, with one field containing a number 0-12, a pulldown list containing Low/Medium/High/Maximum, and a slider labeled "small file" on the left and "large file" on the right. The visual appearance is a little different, but it has the same info and layout as the one here.cactuspic wrote:Rik, thanks for the info, but I don't get a slider for quality control in the "save as" function. I do get the slider in the "save for web" function. Am I doing something wrong? I have CS3 for the Mac.
