Hope you enjoy.
Irwin
This is a composite of 43 images stacked in Helicon and hand layered.
Thanks Rik. I have been working hard on my stacking technique. After I compile my image in Helicon, I typically go into the retouching function where I go to each individual slice and paint in the areas that are in better focus on the slice than they are on the composite. It's tedious and time consuming but it eliminates mush out and problems where the program mixes up foreground and background. If your lighting is consistent, it works well. Otherwise, I adjust my images in raw to make them more consistent. While the program can account for some lighting divergence, hand layering cannot.rjlittlefield wrote:This is great! A beautiful flower, well composed and lit, sharp as a tack, and I don't notice a single stacking artifact.
You say "stacked in Helicon and hand layered". Does that mean manual touchup of a single Helicon run, or did you run Helicon on multiple slabs and then put the partial results together by hand?
