Irwin,
Welcome to the world between macro and micro
The Nikon M-Plans are "metallurgical" objectives. As such, they are intended to be used without a coverglass. This doesn't matter too much at the lower powers (5X, 10X) but when you get into higher power objectives (20X and up) it is an important characteristic for this type of use -- on bellows as a "macro" lens. It means much less spherical aberration.
The other intriguing aspect is that they made some that were fully corrected for chromatic aberration in the objective itself... older "biological" objectives typically used some chromatic correction in the eyepieces. I am not 100% sure, but I believe this was also the case with the older "M" style objectives. They also made some higher magnifications with greater working distance than normally encountered for their magnification. These are labeled "LWD", "ELWD", or "SLWD".
As you have shown us here, they can give excellent results. The older ones may show some chromatic aberrations toward the picture edges. More recent ones were of Nikons "CF" design and are better as far as chromatic aberration is concerned. (Unfortunately when they made this change they did not mark the objective barrels with the "CF" designation as was done with their "biological" objectives).
You'll probably find you can get good results at higher magnifications with even more bellows extension, but with your full frame 1Ds you don't want to go less than to 210mm. (And even at 210mm you may find that the edges using a "full-frame" camera may not be as good as the center).
Just about all currently manufactured objectives of this type are now of "infinity" optical design. These should not be used on bellows as "macro" lenses.
Charlie
