I've been trying to see how much magnification I am comfortable with when making stacked images on a tabletop with camera bellows and such. The precision and stability of a compound microscope (don't have a good stereo) is wonderful, but it can sometimes be troublesome getting the subject at the proper angle, and setting up the lighting and background can get tricky.
So this fly happened along just as I was going to try a 20X shot. The "overall" shot lets you know what you are looking at in the two images below it.
The 20X looks very clean and detailed with no obvious distortion...how much further do you think you can push the magnification with your current tabletop setup?
Bruce... I think 20-25X is about as far as I will go regularly. The optics are not especially the problem, it's the "physical", mechanical part. Vibration issues grow exponentially. If a car drives by outside I see things jitter. I even turn off the stereo. (otherwise, when BB plays the blues my subjects bounce around in rhythm with the sub-woofer!) I've got a few more tricks to try, but after 20X the stability and precision of my Olympus BHS is awfully appealing.
Can only copy Bruce's comments - excellent as usual.
As regards vibration issues, I was wondering if something like a false plinth / top placed on the table top and mechanically isolated from it might help?
If I ever tried this sort of thing, I'd have problems with false / non concrete floors in most convenient parts of the house and considered whether a slab of marble, approx 30 in square, 1in thick (which I already have) supported by 3litre wine box bladders, semi-inflated, would be worth trying?
I know when I worked in optics, in the QC room, they had a table that was on four rubber inner tubes and one that was leveled by automatic air cylinders on all four corners. The table was made of steel and weighted 600 lbs. ALso, I know with the larger telescopes from Meade and celestron, they sell these little donut things called vibration surpression pads to put under the legs of the EQ (sorry Equatorial mounts) mounts. http://www.celestron.com/c2/product.php?ProdID=380
I have moved the camera and subject stands on to a 3" thick laminated wood platform that rests on the counter-top. (Before I did that, if I leaned even lightly on the counter-top, the slight "flex" of the surface would change focus about 3 DOF distances!) A heavy slab of something like marble would be even better... and Doug, that 600lb steel table sounds like just the type of "overkill" (for my situation) that is fun to contemplate.
.... hmmm ... maybe it's time for a trip to Boeing surplus....
<< that 600lb steel table sounds like just the type of "overkill" (for my situation) that is fun to contemplate. >>
Make one wonder about how a 10cu foot (or greater) container (with decent, smooth, flat) top would perform - when filled with water and (also) mounted on isolating pads ...
The DIY anti-vibration table I heard of was an inflated car inner tube with a 2" thick 3ft x 2ft concrete paving slab placed on it. I would think one slab would weigh about 160 pounds, so you could put two on top of each other if you wanted and use two inner tubes to support their length if needed.
Failing that you could always put "In the still of the night" on the stereo!
Fortunately there is little traffic by my house, and I can keep the stereo off. But since I have a separate "subject" stand and "camera" stand it really becomes important to avoid any "flex" in whatever base they rest upon. And I've been amazed at how little force is needed on most surfaces to cause a deflection that becomes very noticeable through the camera.
