Upper image: Stand of Stemonitis axifera
Scale of frame, 18mm horizontal
Canon 10D
Fuji 50mm lens @ f/3.5 on extension tubes
Series of 102 images at .0025 inch increments
Diffused fiber optic illumination
Combine ZM, Photoshop
Lower two images: Early axifera emergence
Scale of frame, 5mm horizontal
Canon 10D
Canon 20mm Macro @ f/5.6 on extension tubes
Series of 95 images at .001 inch increments
Series of 118 images at .001 inch increments
Sorry to have neglected you all for a while. So busy. Stemonitis has many species but I believe that I am correct in naming this one. They are quite common and macroscopic. It may be hard to believe but the lower two images are of the same species. Seen here very early in emergence I watched the transformation of these blobs into something close to the top image over 12 hour period. Unfortunately as I and Ken have explained in previous posts they never mature properly so I had to go back into the field and take the sample you see in the top image to show the finished myxo ready to release it’s spores.
Walt
