The macro that isn't a macro!
arlon
Post by arlon »
I wanted to copy some old family slides so I made a fixture to use my 55mm micro nikkor to take some "macro" shots of the old slides..
It worked amazingly well..
Here's a macro shot of a slide from 1957. Yes, it's me.
My custom macro rig for copying slides:
D50,100 IR, 90, 700, 800E and a box of old manual lenses.
tpe
Post by tpe »
Well done it did work great, I did something similar and used a ring flash to illuminate the back screen, but still not as sophisticated as yours (mine was all cardboard :). I think the resolution and sharpness are probably better than if you had used a amerteur slide copyier.
tim
arlon
Post by arlon »
My first one was all cardboard then I upgraded to a piece of PVC pipe, then found a real slide holder for $10 at a camera shop.
The 55mm micro lens worked better than anything else I tried. Resolution full scale is pretty good too if the original was decent.
With everything screwed down to a 1/4, camera movement isn't an issue and you can get by with some fairly slow shutter speeds.
More examples out HERE.
And if the slides are curved too much, you can even shoots stacks for better resolution corner-to-corner.
No joke -- been there, done that! It seemed a bit silly, but it sure beat the Newton's rings I kept getting when I tried to flatten between glass.
arlon
Post by arlon »
rjlittlefield wrote:And if the slides are curved too much, you can even shoots stacks for better resolution corner-to-corner.
Haven't had that issue yet, usually shoot at f16-22 and have plenty of DOF. Stacking is an idea though. CombineZM would have been useful when I was trying to do them purely by hand.. Used it for a few other things but not slides yet. Keep the ideas coming! Arlon
