There's obviously a wing there Ken but it's hard to make out what it is. In fact the blade of grass was blowing so much at times the Damselfly nearly fell off and was left hanging underneath. In the end I managed to get hold of the base of the grass stem to steady it a bit before it flew off but the top was still waving around.
It still lacks the quality and crispness of flash to me. I really will have to read the manual and set up my as yet unused flashes using the menu. Oh for the good old days when you just needed to stick the flash on and turn the shutter speed knob to sync speed instead of trolling through enough menu options to set up a Web site.
I still miss setting things with single function knobs and buttons, although for most usual functions the Nikon D200 does use these, you only have to use the menu if you want to set up something different. What I need is a child of 4 to set it up for me!
DaveW
