Caronte wrote:It is an interesting issue. Do you think we should picture nature as it is, or should we use all of our resources to get what we want?
Yes, yes, and absolutely!
You may have noticed that I have a great fondness for stacking, which produces images that no lens could ever project. I sharpen mercilously, especially when working near diffraction limits. I stretch histograms and warp curves to get the most dynamic range, I blur backgrounds to improve their appearance, and I'm not above manually retouching backgrounds and even subjects to eliminate confusing and distracting elements.
On the other hand, I try to make sure that all these efforts simplify or at least do not complicate the task of someone trying to make sense of the image.
The
Posting Guidelines are necessarily a bit ambiguous about this issue:
Digital enhancement of an image is allowed. Common enhancements such as contrast control, color corrections, cropping/resizing, noise reduction, and routine sharpening can be done without comment. However, any enhancements that alter the "naturalness" of the subject must be declared in the image post. Any type of "stacking" or image compositing should be noted; so should extreme or unusual amounts of cropping, sharpening, etc.
If I may be permitted the pun, adding "shadows" is in a gray area.
I can easily imagine different people disagreeing about whether this is a "common" enhancement, or whether it "alters the 'naturalness' of the subject". Personally, I would prefer the enhancement had been mentioned as such.
It
is a lovely image.
