Thamnophis sirtalis sirtalis. A very common snake in these parts. Not agressive at all. If you pick them up, they might try and bite you, most times they don`t. When first captured they will discharge musk from glands at the base of the tail...very stinky stuff. Their natural foods are mostly cold blooded like frogs, fish, salamanders, tadpoles and earthworms. Head and body about the size of an average pinky finger. This one was about 18" (46cm) long. There I go again...stomach on the ground to get the shot.
Does "on your belly resting on two elbows" count as a super-steady support (thats like a three legged support ? Usually I leave it on all the time. I am trying to remember to turn it off when using my tripod. These were taken hand held. Do you think I should have turned it off?
beetleman wrote: Do you think I should have turned it off?
I've noticed that with my 100-400L lens, if I'm holding it supported on both elbows on an a solid base, often (presumably when I'm doing an especially good job of being stable) the image gets a bit blurry when viewed at 100%.
My suggestion is that you just take some shots from the same position with IS on and IS off and the examine the images at 100%. If there's not a difference you can tell, you can choose whether or not to have IS on or off. If there is a difference between the shots (when experimenting with this sort of thing I either write down notes, or take several one way, then take a totally different shot (maybe a non-macro in your case) to mark when I switched techniques, then take a couple of shots using the other technique I want to try.
