Thanks guys!
Mike B in OKlahoma wrote:He looks translucent (like you can almost see through him) is that the way he looks in real life?
No Mike, these are just different shades of gray, I think the flash makes it then look translucent. I think the last image at the end of this post shows it nicely.
twebster wrote:I definitely love the low angle you got, too.
nzmacro wrote:Yes the low angle works well M8t.
Yup, I was quite low on the ground. I was using the Manfrotto (Bogen) Monopod Support, I think it is 3422 or so. It helps a lot getting steady support for the pod. Just the mini mall head is a bit on the small side.
Ken, Doug and Nikola - thanks guys. And Dave for the interesting link. The one photographed in the picture is smaller than the ones in that link. The pure body length is roughly half an inch (a bit over 1 cm).
Bruce, here is the crop you want to see that shows more head detail:
and here is an older image, that shows one of its relatives after murdering many small flies and moth
Waterstriders are close relatives being in the same family with the same hunting and killing behavior. I'll post an older image in a new thread.
Thanks again everyone for looking & commenting.
Sven
If you are out there shooting, things will happen for you. If you're not out there, you'll only hear about it. - Jay Maisel
