Very nice Nikola.
I find images like this hard to compose. Subject fills the frame but still does not look quite right because of its length and then I consider a verticle composition but still again that does not look right either, maybe because of the background or substrate that it may be posed on, so I go back to the horizontal and hope for the best.
You have a good image here.
Sharp, good color and pleasing background. You had reservations about ISO 800, so do I. I have been shooting at 400 for a good while but as of today have gone back to ISO 100 in lieu of using a NR program, which brings me to ask, did you use one on this photograph? The reason I am inquiring is that, (1) it is very clean for ISO 800 and (2) I notice some compression artifacts around the tail or abdomen of the damsel, though they are very slight and you really have to be looking for them. Also your signature gives them away really good if you look closely. The reason why I notice these artifacts so much is that I used to see them all the time, around my signature especially, when I used Neat Image Demo.
Could be the retail version does not have this problem, since the demo, quite obviously, is only for demonstration. Just the same, NR or not, you have a really nice photograph here.
By the way, I noticed the camera settings and the lens mm. Did you by chance get a EF 100mm macro for your xti?
