Bruce,
1) Distance to subject - hmm, knew this at one time, but I would guess I am 9-11 inches away. Far enough away to not scare anything away except for skittish butterflies.
2) Cropping has been variable. I rarely do any heavy cropping as the image looks too pixelated. I rarely chose to post full frame, as there was always some distracting element I wanted out of there. Also, many times I wished to zoom in a bit...not that I would have needed to if I had composed the shot correctly the first time, but I had only been shooting macro with a DSLR and this lens for several months at the time.
Can't really give an average crop factor, but would guess area-wise, the end result is usually 2/3 - 3/4 of the original.
3) Exposure - no, down there my exposure was usually slightly underexposed...had to lighten post processing. Focus was usually great, the vast majority of my shots are in nice focus. However, this is a heavy lens and I use a monopod. Tripod would have been better, but did not use one. Have taken some nice ones without a monopod too, but have fallen in love with the support a monopod gives.
4) I will do one better on the full-size crop question. You tell me an image you want to see the original of, and I will either send to you (file size may be prohibitive), or give you a crop of the area you specify if you want RAW. If you just need a post processed jpg, , I can also send you a link to one, such as
http://perceptions.smugmug.com/gallery/ ... 44074-O-LB
Ken
