First ant of the year
We have a frog in Hungary whitch became blue while mating (Moor Frog (Rana arvalis)). I went to the swamp and searched for it. I missed it again this year. Maybe next year.
But I found ants. So I photogrphed ants instead of frogs.
Here it is:
Lasius fuliginosus
Canon 20D + reversed 18-55mm
One interesting thing. I found something in one of the picture. It is not the sharpest one... Maybe it is some sort of parasite. What do you think?
Here it is:
Lasius fuliginosus
Could be a parasite, too bad you cannot get that ant under the objectives of a stereomicroscope for a real close look or a good set of extention tubes even. It does look as though something is erupting from the corner of the eye but from what there is to see, nowhere else. You may want to examine the entire photograph of the ant a bit further to see if there are anymore eruptions like this, especially around the leg and abdominal joints. Not all parasitic infections affect the host the same way and that can be a clue to what sort of parasite that it is, if indeed it is one.
WooHoo!
Gordon would be greatly delighted!
A kind of those miniature spiders Ken usually found in the moss?
errors are welcome.
errors are welcome.
- Planapo
Péter (I hope this is your first name, don´t wanna be impolite), most probably it is a mite on the eye of the L. (D.) fuliginosus.
A question concerning the gear you used: Did you use the kit lens (EFS 18-55 mm 1:3,5-5,6 II)? And what kind of reverse adapter did you use and was a bellows or extension tube in-between?
Kind regards.
Betty
Kind regards.
Betty
Hi Betty!
Yes Péter is my forename, but in Hungary it is not the first.
I use a homemade reverse adapter it is made from an extension tube. Novoflex has reverse adapter but that is a way more expensive than mine.
The kit lens is not the best, but this is the only lens I can use for this purpose now.It produce relatively big DOF but not so sharp as my other equipment I use for this kind of magnification (Canon 100mm macro + 55mm lens reversed).
There is no need for extension tube, and it is not the best magnification either...
Péter
Péter
- Mike B in OKlahoma
Very good shot here. I know from experience that ants are very tough to get posed and in focus.
That looks like a mite to me. Hopefully Gordon Snelling will come along soon. He will know more details, I'll bet! :-) As will Jody.
