Comma butterfly
Comma butterfly
Polygonia c-album. See an explanation of his name on #3. :D
It has a white marking on its underwings resembling a comma.
Camera model Olympus u720SW
Date/time 11.06.2006/14:45:41
Exposure time 1/400 s
F-number f/7.1
ISO 64
Focal length 9.13 mm
Date/time 11.06.2006/14:46:16
F-number f/5.6
ISO 64
Date/time 12.06.2006/11:11:50
Exposure time 1/320 s
F-number f/5.6
ISO 64
You know all three of these are good but I especially like the third or last image. It seems to have a sense of movement about it. Very nice Nikola, very nice. :D
This is one of my favourite butterflies - it's all in the distinctive wing shape of course. From the light (beautifully marked) underside of the wing I would say this is probably a male.
The Olympus u720SW is not your usual camera is it Nikola - so how do you find it compared to the Olympus SP-320?
I have an Olympus SP-350 which is permanently fitted to my Meiji stereo microscope. I've not yet tried using it for close-up photography (I normally use my Minolta A2 and sometimes the old Fuji 6900z). Seeing the excellent results you've been getting with your SP-320, I'm planning to use the Sp-350 in the field this spring/summer/autumn with the benefit of small size/portability.
Bruce
Thanks folks! :D
Bruce, I mainly use SP-320 but have also u720SW and C-770UZ in my pocket/knapsack. Both cameras (SP-320 and u720SW) are 7MP. My subjective feeling is that u720SW gives a little more DOF.
u720SW lens has 6.7 – 20.1mm (38 – 114mm equivalent in 35mm photography), focus range Normal mode: 19.7” – infinity (0.5m – infinity); Macro mode: Wide: 7.9” – infinity (0.2m – infinity) and Super Macro Mode: 2.8” – 19.7” (7cm – 50cm).
SP-320 lens has 8.0 – 24.0mm (38 – 114mm equivalent in 35mm photography), focus range Normal mode: (wide) 7.9” – infinity (0.2m – infinity); (tele) 11.8” – infinity (0.3m – infinity); Macro mode: (wide) 7.9” – infinity (0.2m – infinity); (tele) 11.8” – infinity (0.3m – infinity); Super Macro Mode: 0.8” – infinity (2cm – infinity).
Although there is a difference in minimum macro distance (2cm SP-320 and 7cm u720SW) I did not see so big difference in macro capabilities, possibly because u720SW objective is all inside thin body in contrary of SP-320 which extends significantly out.
I also found one difference by chance. I usually attach my copyright notice to 800×600 photo with font size "24" but in case of JPEG from u720SW this size is too big and I must reduce it to size "6". A cause for that I found in EXIF properties. Resolution of SP-320 JPEG is 72 per inch and of u720SW is 314 per inch. :?: :shock:
Model u720SW is water resistant without housing down to 3 m deep but I didn't try it yet, shame on me. :oops:
Super macro mode for your camera model SP-350 is also 0.8" - infinity (2cm - infinity). On eBay you can even find filter adapter and HD close up macro lens +1, +2, +4 and +10 diopter for it.
All three are super but I like the second one..wings open and the beautiful flowers.
