This fellow did a biiig stretch, raising its abdomen high. It must be quite a fresh specimen, seeing its thorax is still totally translucent. You can see its 'drinking straw' (the brownish straight line).
The leaf is ngaio (myoporum laetum), a NZ native shrub/tree; the larger dots in the slightly leathery leaves are said to be oil glands. This is the only host in my neighbourhood for the spittlebugs.
Dynax 7D @ ISO 200
100-300mm + reversed 50mm + extension
F32
flash
cropped vertical from horizontal, less a smidgeon of foreground
