The second tooth, is my upper left wisdom tooth. Upon examining my teeth when that first tooth became a problem, the dentist determined that my wisdom tooth was also starting to decay from the inside a bit and it wasn't being used anyway (my bottom wisdom teeth were pulled years ago). There's a cut in the tooth so that they could pull it better:
This tooth is interesting because some of the bone came with it, as you see in this shot (hope you're not squemish):
Now, grossness and such aside, what about the technical details of these images? Did I do a good job capturing them? Enough detail? Lighting?
Canon EOS 300D (Rebel)| ISO 100 | 18-55mm@55 (+4+2+1) | 1/50s | F22 | Flash | Handheld
