Interesting thread.
I am just finishing a setup using a full frame camera:
Sony a900
Sigma 180mm f/5.6 macro
Mitutoyo 5x na 0.14, 10x no 0.28
I am wondering if I should try a ranox.
A quick test showed that the objective didn't vignet too badly with a 90mm tamron macro and a cropped sensor (sony a350), so after a lot of experimentation I may move to a 120-135mm focal length. The experimentation to check corner blur with the tamron.
Short listed would be a Carl Zeiss 135mm f/3.5 (m42 fit) or a ranox 250 (diopter 8, about 125mm focal length).
The CZ is a good lens, with little fall off in quality in the corners, but will the ranox be better? Can anybody sugest an even better choice?
Infinity objective with Raynox DCR-150 as tube lens
- Craig Gerard
Joaquim,
See the comments by Bob S.
Should be rather easy attaching a UV filter to the Raynox.
The prices of the 'Baader Fringe Killer' don't look too severe.
I don't know anything about them.
Is anyone using them for macro, if so, why?
http://www.cloudynights.com/item.php?item_id=27
Rather than simply trimming the shorter wavelengths at a chosen wavelength and slope like all other minus violet filters, the Fringe Killer carefully attenuates a specific region of the spectrum. This allowed Baader to tune the filter for maximum practical reduction of the most damaging defocused blue wavelengths, with only a faint yellow color shift - without dimming and lowering image contrast by resorting to reduction of the important green-yellow wavelengths to crudely restore an apparent color balance! (where the eye is very sensitive, and where refractors are their sharpest) The result is a filter that removes the majority of color fringe, without affecting image brightness all, imparting strong coloration, or reducing contrast at important wavelengths.
