These are my first "subjects". The ant was photographed at 7.5X, but this is a (squarish) vertical cropped from a horizontal shot. The leg joint of the jewel beetle (Chrysochroa rajah thailandica) was at 12X. The iris anther was at 7.5X.
Mitutoyo APOs, really top models in infinity microscope optics! Please can you give details about the tube lenses?Charles Krebs wrote:Set up a Mitutoyo BD 10/0.28 Plan Apo with 150mm and a 240mm tube lenses
For me the necessity of different focal for each magnification is one of the greatest inconveniences of the infinity system, a lot of optics and distances changes for a specific magnification...Charles Krebs wrote:These are my first "subjects". The ant was photographed at 7.5X, but this is a (squarish) vertical cropped from a horizontal shot. The leg joint of the jewel beetle (Chrysochroa rajah thailandica) was at 12X. The iris anther was at 7.5X.
The 150/9 is an Rodenstock Apo Gerogon, the 240/9 is a Beseler Apo HD (which is actually a 240/9 Rodenstock Apo Gerogon). These are "short mount" and need to be used on a bellows. The magnification can be changed by varying the extension, but so far I have only used them at "infinity". I'll need to do some careful comparisons to see what happens to the image quality as the bellows extension is changed. (I'll take a picture or two and post it over in the "equipment" section if you are interested in seeing it set up).Please can you give details about the tube lenses?
Of course, I always learn interesting things watching your setups!Charles Krebs wrote: (I'll take a picture or two and post it over in the "equipment" section if you are interested in seeing it set up).
Charlie wrote:The 150/9 is an Rodenstock Apo Gerogon, the 240/9 is a Beseler Apo HD (which is actually a 240/9 Rodenstock Apo Gerogon). These are "short mount" and need to be used on a bellows. The magnification can be changed by varying the extension, but so far I have only used them at "infinity". I'll need to do some careful comparisons to see what happens to the image quality as the bellows extension is changed. (I'll take a picture or two and post it over in the "equipment" section if you are interested in seeing it set up).
.. no, never did. But with the recent interest in these infinity optics, and now Nikola's question, I'll try to get a few shots posted over in the "hardware" sections. I will add a message here when this is done and where it is posted.Did you post some images of this configeration at some time?
Yes, that is the objective. This turned out to be one of those rare, but nice coincidences. I use some old Ihagee Exakta microscope attachments. Part of these have the same threads as the tubes used in Ihagee Exakta extension tubes... M40 x 0.75. These BD Mitutoyo objectives screw directly into those tubes. (You can see what they look like at eBay# 120329805269). Be sure to get the original German-made Ihagee tubes. Some of the similar looking extension tubes that were made by other companies (for Exakta cameras) used a slightly different thread). The extension tube set consists of three threaded tubes (M40 x 0.75) and male and female Exakta bayonet attachments that fit on the ends. I also discovered that the Nikon tube lens, if "shimmed" a little bit, fit very nicely inside one of he larger tubes. I'll try to get a few pictures later today or tomorrow to show exactly how it was all put together.I bought one and was shocked when I saw its huge size and the 40mm thread. How did you attach to the tube lens and which lens you have used?
