www.photomacrography.net :: View topic - Hello from North Wales
Goto page 1, 2  Next
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Community Members and Friends
pgk
PostPosted: Mon May 17, 2010 1:38 am    Post subject: Hello from North Wales Reply with quote
Hi. I'm Paul and I'm a North Wales photographer specialising in underwater photography. I shoot a lot of macro underwater and currently use a Canon 5D2 with 100usm macro and 60 EFS macro (with a 12mm extension tube this lens just covers full frame). You can see a few of my macro images here:
http://www.paulkayphotography.co.uk/Paul_Kay_Photography_Underwater_2.html
http://www.paulkayphotography.co.uk/Paul_Kay_Photography_Underwater_4.html
http://www.paulkayphotography.co.uk/Paul_Kay_Photography_Underwater_6.html
Although I've shot plenty of macro at around 1:1 before, I am now building a macro set-up for higher magnification seashore photography and also for micro aquarium work (I'm making very small aquaria from transparent plastic boxes with cut outs and large coverslips fitted over them). I want to shoot in the 2~15x range I think. So far I've modified a Leica R tube set to fit Canon and added several more tubes to give me a very portable and rigid system and am awaiting a Thorlabs translation stage to get it all up and running. Any comments or tips on field equipment will be welcomed when I've started to use it and can post some images.
Paul
Craig Gerard
PostPosted: Mon May 17, 2010 1:53 am    Post subject: Reply with quote
Superb images Paul!
Welcome Smile
Harold Gough
PostPosted: Mon May 17, 2010 2:37 am    Post subject: Reply with quote
Wow! That lobster (crawfish?) portrait is stunning. (A strong candidate for the monthly Appreciation award?).
We don't get many marine inverterbrates shots here. (I'm not too sure of the scope of the microscope specialists).
Harold
PostPosted: Mon May 17, 2010 4:22 am    Post subject: Reply with quote
Welocme aboard Paul!! Great shots there Very Happy
Canon 30D | Canon IXUS 265HS | Cosina 100mm f3.5 macro | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Slik 88 tripod | Apex Practicioner monocular microscope
View user's profile Send private message Visit poster's website MSN Messenger
pgk
PostPosted: Tue May 18, 2010 8:50 am    Post subject: Portable set-up Reply with quote
I've finally sorted what I hope may prove to be a usable set-up for use on the seashore. It might be of interest to others as I've used existing, readily available parts - mainly used Leica/Leitz items - and have converted them for use on the Canon with a Leitax mount. A mix of RRS, Kirk, Arca and Overxposed components together with a Thorlabs stage have finally completed this. My aim has been for rigidity at the expense of some versatility - I opted for tubes rather than bellows and as can be seen these are reinforced with bungee! I can increase tube lengths in 25mm increments (bottom centre) and have several adapters including Leica 39 screw thread (bottom left). Any comments will be welcomed regarding any improvements or suggestions.
Paul
dunksargent
PostPosted: Tue May 18, 2010 9:11 am    Post subject: Reply with quote
Hi Paul, Good to see you here and your setup looks 'THE BIZ!' . Look forward to seeing the results.
Cheers
dunk in Peterborough UK
And now for something completely different.
Aynia
PostPosted: Tue May 18, 2010 12:35 pm    Post subject: Reply with quote
Wow. Superb images - especially the Scottish lobster!! How did you light them? Just flash, macro flash, or some kind of light?
I'd never venture that far underwater, but I am curious about the light because they are beautifully lit.
pgk
PostPosted: Tue May 18, 2010 2:15 pm    Post subject: Reply with quote
Aynia
Thanks.
I usually use a single flash unit - most underwater ones are typically wide beam - usually in front of the lens, low and to one side. This seems to give effective results as the size of the tube and reflector is pretty large compared to many subjects.
dunk. Its a small world these days!
Paul
dunksargent
PostPosted: Tue May 18, 2010 3:17 pm    Post subject: Reply with quote
pgk wrote:
Aynia
Thanks.
Very small indeed ... especially in the Photomacrography Forums
Cheers
dunk
Laughing
Aynia
PostPosted: Tue May 18, 2010 3:22 pm    Post subject: Reply with quote
Thanks for the explanation.
I think these are exceptional photos!!!
I wish I'd taken them!!
(I am totally camera-less at the moment which perhaps makes me more envious!!!!)
The BAT
PostPosted: Wed May 19, 2010 5:29 am    Post subject: Reply with quote
Hi Paul,
It's lovely to see you posting on this site. I'm now permanently 'unable' to dive and have been having a lot of fun putting my u/w camera to good use on land.
Your ideas of the small aquaria and sea-shore photography sound very exciting and it might be a way that I could also get back some of my 'sea-legs' ???
I learnt a tremendous amount from you during our discussions through the U/W forums and I'm sure that your experience will be very valuable around here. . . . hopefully.
Bruce
PostPosted: Wed May 19, 2010 5:39 am    Post subject: Reply with quote
Fantastic set up there!!
PostPosted: Sat May 22, 2010 9:20 am    Post subject: Reply with quote
Paul,
Welcome! Great images.
Quote:
(I'm making very small aquaria from transparent plastic boxes with cut outs and large coverslips fitted over them). I want to shoot in the 2~15x range I think.....
... Any comments or tips on field equipment will be welcomed when I've started to use it and can post some images.
I've worked a bit with little tanks like you describe.
One thing that I've thought of trying for some time has been a "micro" tank with a very flexible vinyl or polyethylene front that has a glass lens port that can be attached to the front of the lens. With high magnification through glass (even cover slip thickness) it's best to have the lens axis perpendicular to the glass, which is not always easy to do without compromising an image "composition". A "bag" front would take care of that issue, and allow for much more freedom in the approach to the subject. This would probably only work with larger "mini-tanks" (how's that for an oxymoron!) and with certain subjects and modest magnifications as the movement of the lens would create currents and water level changes that would move small unattached subjects around too much. Might be impractical and more trouble than it's worth, but I've often wondered...
Yet another "odd" thought I've yet to try with mini-tanks stems from the frustration of being unable to move the subject around to get it at an appropriate distance and orientation to the camera or front window. Have the immobile parts of the mini-scene attached to small base plates of metal. These could then be moved/rotated via a magnet under the base. Again, probably only useful with only certain subjects, but there have been times I would have loved that capability. Worth the trouble...?
Craig Gerard
PostPosted: Sat May 22, 2010 6:05 pm    Post subject: Reply with quote
Paul,
I noticed a snippet of information regarding Aquarium Slides on Graham's (gpmatthews)website. (right-hand side of page)
Micro aquariums:
http://www.gpmatthews.nildram.co.uk/index_micro.html
The BAT
PostPosted: Sat May 22, 2010 6:13 pm    Post subject: Reply with quote
Hi Charles,
There is a company called Ewa-Marine that specializes in 'plastic bag' type underwater housings for cameras/videos. These 'bags' are waterproof and each one contains a quality optic port that the camera lens attaches to and 'sees' through. I see no reason why the process couldn't be reversed with the water and aquatic subjects on the inside and the camera attached to the port from the outside?
HTH. . .
http://www.ewa-marine.com/index.php?id=7
Bruce
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Community Members and Friends All times are GMT - 7 Hours
Goto page 1, 2  Next
Page 1 of 2
