www.photomacrography.net :: View topic - Infinity objective on low-end zoom telephoto works fine
Goto page Previous  1, 2, 3 ... 9, 10, 11, 12  Next
Blame
PostPosted: Sat Jan 29, 2011 5:50 am    Post subject: Reply with quote
Charles Krebs wrote:
I think a key attribute of these would be the ability to get the "tube lens" diaphragm very close to the objective; something that is not easy to do with SLR lenses.
That is certainly a problem. One of the options I am considering is a 135mm f/2.8 Pentacon. The early "bokeh monster" version. I have the 200mm version and it's diaphragm is right out at the front. Zoom and the diaphragm moves out with the front lens. Coated but not multicoated. Amateur reviews show it to be sharp stopped down a little, but I have no certainty regarding corners.
I am also thinking of the 135mm f/3.5 Zeiss on the grounds that is has reviewed as very sharp corner to corner and wide open. As good as the best modern lenses. It has a very similar design to the Pentacon but diaphragm at the back. No real certainty that it will give such excellent results as a tube lens.
I have ordered a Morfanon, but god only knows how long all the adapters and extension tubes will take from China. Morfa showed it working well down to 160mm but it struggled a little at 120mm. Finite objectives are not usually happy run with seriously shortened tube lengths so I am just amazed it worked so well. Would the the "perfect" short tube lens do better? I figure it is worth trying.
Morfa added further confusion to the mix with the possibility that a thin lens might be the way to go. The morfanon is probably an example of trading a more primitive design against a better fit to the required characteristics, and now you are advising process lenses that trade the other way.
Arrrgggg. None of these options is demonstratively or clearly ether perfect or just the best available. Worse, there is no hope of any other solution than trial and error. I could also very likely be after something that just can't be done.
PostPosted: Sat Jan 29, 2011 6:25 am    Post subject: Reply with quote
Does your 200mm Pentacon with its "diaphragm right out at the front" give a large image circle?
You speak of Morfa using his tube lens down to 120mm - not possible, it's a longer lens than that, so I don't know what you mean. Confused
PostPosted: Sat Jan 29, 2011 6:39 am    Post subject: Reply with quote
Has anyone tried a lens like this with an infinity objective?
http://cgi.ebay.co.uk/KODAK-PROJECTOR-LENS-VARIO-RETINAR-S-AV-2000-ZOOM-/270698699006?pt=UK_Photography_OtherAccess_RL&hash=item3f06e658fe
It's a slide projector lens, so it's designed to:
cover 24 x 36 (unlike a view camera lens)
work at fairly long distances one side ( ok, not infinity)
work wide open.
This one's an 85 - 200 zoom, which would be a useful range. With projector lenses in my experience the whole glass-containing part isn't generally very long, so it might be that the entrance pupil is well forward.
Blame
PostPosted: Sat Jan 29, 2011 7:02 am    Post subject: Reply with quote
Morfa's lens is a 172mm, but he used it with various tube lengths. The shortest gave a 6x magnification with a 10x lens. It is perhaps technically incorrect to say he reduced it to 120mm, but think of it as zooming.
I am going to stick to fixed focal length options as they tend to give better results but I am certainly considering projector lenses. The big catch is finding out how good they are before parting with my money.
The Pentacon 200mm is no test. Just about anything works at 200mm. The trick is getting lower. I am not even going to bother until I have the morfanon lens + adapters to compare it with.
PostPosted: Sat Jan 29, 2011 7:51 am    Post subject: Reply with quote
Not what I've found.
dmillard
PostPosted: Sat Jan 29, 2011 8:12 am    Post subject: Reply with quote
"When I use a word," Humpty Dumpty said in rather a scornful tone, "it means just what I choose it to mean -- neither more nor less."
"The question is," said Alice, "whether you can make words mean so many different things."
Sorry . . . I couldn't resist! Smile
David
Oskar O
PostPosted: Sat Jan 29, 2011 9:17 am    Post subject: Reply with quote
I'm kind of skeptical about a projection lens producing the desired quality, but I don't mind being proven otherwise Wink
There are plenty of decent 135 mm small format lenses, especially when performance stopped down is considered. They also don't cost so much. My intent is to start testing a bit with my 135/2.8 Nikkor once I get more adapters, but it's a fairly simple lens, nothing fancy.
Blame
PostPosted: Sat Jan 29, 2011 10:25 am    Post subject: Reply with quote
Damb. You mean I may have spent a whole £5 on a lens and it might not work? Sigh. I might be reduced to using it for taking pictures.
Anyway, right now the adapter is somewhere between here and china, so I guess I will have to wait & see.
Blame
PostPosted: Sat Jan 29, 2011 10:28 am    Post subject: Reply with quote
dmillard.
Humpty Dumpty?
I really should put more effort into this diet.
conkar
PostPosted: Sat Jan 29, 2011 12:35 pm    Post subject: Reply with quote
I wonder one thing about this......., or two.... Laughing
A Zoom objective have more lenses and groups than a prime, so is it an advantage or disadvantage with more or less of lenses and groups in the objective?
In my own theory of the ray of lights it should be an advantage to use a prime objective together with a infinity microsopic lense.
Had anyone done a test with a polarizing filter between the microscopic lense and the camera sensor?
Regards,
Conny
Blame
PostPosted: Sat Jan 29, 2011 1:58 pm    Post subject: Reply with quote
Hi conkar.
From reports of users, you appear to be correct. Generally primes work better. They vignette less. Exactly which lens is best is still a matter of heated debate and frantic testing.
A polarizing filter is something I had on the "to do" list. It has been used by others here with great effect on shiny insects. You do need another filter on the light source so as to cross polarize. That way reflected light is cut.
PostPosted: Sat Jan 29, 2011 2:06 pm    Post subject: Reply with quote
I do it a lot, but so far only with finite optics. Works great. NB, I'm using an "analyzer" from a microscope, rather than a polarizer marketed for general photography. Same idea, but since some folks have suggested that an analyzer may offer higher extinction and better color fidelity when cross polarizing, I went with one.
--Chris
dmillard
PostPosted: Sat Jan 29, 2011 2:55 pm    Post subject: Reply with quote
Regards,
Conny
Hello Conny,
I have been playing with an inexpensive rotating 52mm polarizer between a 5X infinity objective and a tube lens, along with some polarizing filters on fiber optic light guides, to look at fire agates. I have an Olympus "analyzer" with which I intend to replace the polarizing filter in its mount, but at the moment I've misplaced it Rolling Eyes .
David
Craig Gerard
PostPosted: Sat Jan 29, 2011 4:12 pm    Post subject: Reply with quote
Classic quote! I was only ever familiar with the nursery rhyme. Must be time to read the book Smile
Those analyzers are rather small; you would not believe the size of the box used by the seller to ship the item from the US. It took about 20mins to find it amongst the polystyrene peanuts
David, check your spare filter containers Cool
dmillard
PostPosted: Sat Jan 29, 2011 5:58 pm    Post subject: Reply with quote
Thanks Craig,
It was in a little plastic bag right next to them! Smile It fits nicely in a Nikon-T-mount adapter directly over the objective, and I've been enjoying playing with it (in incident mode) for the last hour. I really need to crank up the ISO setting on my camera (a more powerful flash may be in order).
David
Page 10 of 12
