www.photomacrography.net :: View topic - Zeiss DSLR adapter on ebay (another one)
SONYNUT
PostPosted: Sun Jan 23, 2011 7:03 pm    Post subject: Reply with quote
now that i look back in my files on my other computer ,that may have been with my other microscope...before i got the zeiss..
Just shoot it......
PostPosted: Thu Jun 14, 2012 12:07 pm    Post subject: Reply with quote
One year later, another sample on eBay, much higher priced than desirable IMO, but it's a fairly rare item:
http://www.ebay.com/itm/Zeiss-Mikroskop-Microscope-Objektiv-f-63-in-T2-Fassung-mit-Klemmring-fur-D-40-mm-/251085569322?pt=Optik_Zubeh%C3%B6r&hash=item3a75ddbd2a
This is the main photoadapter I use;
http://www.photomacrography.net/forum/viewtopic.php?p=99265#99265
PostPosted: Wed Jun 26, 2013 1:35 am    Post subject: Reply with quote
...and now another one, but maybe expensive and just for USA buyers
http://www.ebay.com/itm/Carl-Zeiss-Microscope-Camera-Adaptor-45-60-29-45-29-96-Mount-44-42-31-Eyepiece-/390616415952?pt=LH_DefaultDomain_0&hash=item5af28d7ed0
The complete setup for sale is for some Axios but the camera adapter itself also fits on 40mm external phototube of some Standard and Universal models.
I'ts the one I use in my Zeiss Standard
PostPosted: Thu Oct 24, 2013 2:50 pm    Post subject: Reply with quote
and another one..
http://www.ebay.com/itm/Zeiss-Microscope-Phototube-SLR-Camera-Adapter-0-25x-Catalog-Number-456029-/251363982988?pt=LH_DefaultDomain_0&hash=item3a8675fe8c
Protos
PostPosted: Fri May 09, 2014 2:14 am    Post subject: Reply with quote
I am looking for the same item
Zeiss Axiophot, transmitted and Fluorescence
BK5000, Transmitted and CP
Wild M20
PostPosted: Fri May 09, 2014 5:07 am    Post subject: Reply with quote
Now there are two for sale in Germany but (IMO) at unreasonable prices:
http://www.ebay.com/itm/Zeiss-Mikroskop-Adapter-Objektiv-f-63-in-T2-Fassung-mit-Klemmring-fur-D-40-mm-/371043031030?pt=DE_Computer_Sonstige&hash=item5663e357f6
http://www.ebay.com/itm/Zeiss-Mikroskop-Adapter-Objektiv-f-63-in-T2-Fassung-mit-Okular-S-Pl-12-5x-16-/371057393546?pt=DE_Computer_Sonstige&hash=item5664be7f8a
I think you can made the same with the MC63 camera lens and some brico to mount a dslr on it, the main problem could be its big diameter colliding with the bulit in camera flash if present (this is the adapter that Wim uses)
Protos
PostPosted: Fri May 09, 2014 6:59 am    Post subject: Reply with quote
Hi Pau
yes I had seen this. There is a couple of german shops that always have outrageous prices (including dic stuff) . Don't know if they do sell at this level.
i will look at the MC3 solution.
In the mean time I will try a 2X Lens teleconverter and some M42 extensions
Wild M20
PostPosted: Tue May 13, 2014 8:04 am    Post subject: Reply with quote
Protos,
take a look at this old post:
http://www.photomacrography.net/forum/viewtopic.php?p=91104&sid=43c11dffd592fc1315c06505ef5fe5c4
note that the M35 adapter actually refers to the MC63 lens/shutter and M35 is the detachable 35mm film body.
What camera do you use?
Protos
PostPosted: Fri Jul 25, 2014 6:39 am    Post subject: Reply with quote
Pau wrote:
Protos,
I use a Canon EOS 700D
I has found a system:
T2 ring
a 2x chinese projective
and a 44mm Zeiss adaptor:
Although I get perfect parafocality I am not satisfied with picture quality. It seems that I should get an infinite projective: dunno where to find that: I amnot able to differentiate finite from infinite projectives
I just found a link saying that I should set the camera on infinte mode: no Idea what that means.
Wild M20
PostPosted: Wed Aug 06, 2014 3:36 am    Post subject: Reply with quote
What kind of issues are you experiencing?. Sample images would help.
Take a look at this post:
http://www.photomacrography.net/forum/viewtopic.php?p=140518#140518
I don't know if your adapter is the same, but "chinese 2.5" raises alarm bells.
The best for your Axio will be the original Zeiss projective P2.5 (perfect for FF, a bit too crop for APSC):
http://www.ebay.com/itm/Carl-Zeiss-photo-projection-eyepiece-okular-barlow-2-5x-456021-45-60-21-/301193635758?pt=LH_DefaultDomain_186&hash=item46208a27ae (this one seems expensive, I've seen it for less money in the past)
Another good option will be afocal. Please feel free to ask more info about.
Protos
PostPosted: Wed Oct 15, 2014 9:04 am    Post subject: Reply with quote
finally I just put my Canon at the exit of the phototube (which is in fact a box for axiophot)
much neater image and a larger focal view
Wild M20
PostPosted: Wed Oct 15, 2014 10:02 am    Post subject: Reply with quote
So now you're not using any relay lens. If I understand well you're doing direct projection of the objective/tube lens primary image onto the sensor, am I right?, and what you tell larger focal view is referring to larger field
If that primary image covers well the sensor and the image is parfocal with the eyepieces IMO this is the best method for full corrected microscopes objectives (like Nikon CF and CFI and recent Olympus UIS) or systems with corrective tube lenses (like I think is the case with your infinite Zeiss) in most cases, just with some subjets you could like some more magnification.
Protos
PostPosted: Thu Oct 16, 2014 1:39 am    Post subject: Reply with quote
Pau yes indeed larger field
Smile
thank you for correcting my poor photolanguage.
I just wish I could find a way to "fix" my DSLR to the exit (44mm)
I may use my 44 mm adapter (as pictured above)
also I wish I could use electronic magnification to take pictures; I can only use it to focus (and it works well). I am using the EOS control software that came with my Canon
Wild M20
PostPosted: Tue Nov 04, 2014 6:57 am    Post subject: Reply with quote
Anoter Zeiss photoadapter for sale:
http://www.ebay.com/itm/Zeiss-0-25X-45-60-29-Microscope-Lens-Objective-Pl-10x-20-44-40-31-/381036886889?pt=LH_DefaultDomain_0&hash=item58b7917b69
Protos
PostPosted: Mon Nov 24, 2014 9:07 am    Post subject: Reply with quote
I have the opportunity to purchase it (ref 456021) for 100€; now my question is how to I adapt my Canon on top of it ?
It would fit in my 44C phototube add-on but I have no idea how to add my DSLR on top; Must I purchase as well the ref 456029 ? (not even sure that would fit with this projective)
Wild M20
Page 2 of 3
